New Members: Introduce Yourself Here!
  • Thread starter Thread starter arcadeko
I'm firmly in the Reaper camp, for many of the same reasons you mentioned, plus it works in a way that is very logical to me. I'm not into building beats and loops. For me Reaper works very well as a linear multitrack system.
I played with Cubase LE (I have 3 versions that were included with equipment that I bought). They worked ok, but Reaper just works better for me.
Hi all - just joined the forum! I've been using Tascam stuff since my Portastudio in the 90s. I'm putting together a bigger studio in my house and so my latest acquisition is shown in my avatar - a Tascam M520. Amazingly, it works. But still needs some love. So I decided to join the forum for some advice. I've used digital gear but trying out some old school analog (for the challenge?)...
Hi all. My name is Don. I'm located in New Hampshire, USA. I'm a septuagenarian, and have been playing music since I was in elementary school. I play drums, keyboards, guitar, and bass. I have always had a passion for recording and producing.
Currently I have two different recording setups, one digital and one analog.
Digital wise, I have tried Pro Tools, Cubase, Reaper, and Ableton. I've settled on Ableton Live 12 Lite as a go to just for ease of use. My DI is a TASCAM 16X08 USB.
Analog wise, I have a Peavey RSM 4062, and a REVOX C278.
I have a significant back ground in electronics (30+ years as an R&D tech/engineer).
I will have a ton of questions. Maybe I can answer some questions intelligently. I usually don't speak to what I don't know.
That said, thanks for having me. I have been looking for a forum like this for a long time.
Don
Don
Hello Don. I'm Eric. Welcome!
Don
Hi, I have close to the same setup. I have the Ableton 11 and the older version of the Tascam. I use Ableton more as a traditional recorder in arrangement view, but using the session view can be really a great way to experiment and try differnt things while composing.
Welcome aboard.
Don
Looking forward to hearing what you can do! 8-)
Welcome aboard.
Thanks, DM60, appreciate the welcome.
My situation is a little different, To make a short story long, I went analog for the (seemingly simple) reason that if I want to record an idea, either by myself, of with friends, firing up the computer, launching apps, etc. was too cumbersome, I was able to do that with the DAW, but the latency drove us crazy. (I think it may have been as bad as 5ms in to out). I've tried several ASIOs, but they all gave me issues because apparently, TASCAM's ASIO sucks. I tried ASIO4ALL, but there it still too much latency for live, notwithstanding over dubs, because the latency increases by a factor of 2.
So, I bought the R2R so I can power up, hit record, and go. When the guys came over, we would record 3 or 4 tracks on the R2R, and it was all fine. BUT, if we wanted to overdub and add additional tracks the Revox, I have not been able to figure out how to do that.
Simply, the Revox has a record setting and a playback setting. It's either/or. In effect, I (we) can't listen to the previously recorded tracks while recording new tracks (on unused channels).
What I am looking for is for someway, somehow, someone to tell me how to overdub tracks on the C278. I can record OVER as previously recorded track (due to the way the head(s) are designed), But I can't use the play and record functions simultaneously so I really can't overdub. I can punch in/out one a single track, but that isn't what I need.
If anyone can either tell me 1. it's not possible, 2. do it this way, I will be forever grateful.
So, that's where I'm at right now. I have a A LOT of $$$ invested in the R2R and tape and reels. I want what I want. Call me a Dreamer! I'm not the only one. :)
Thanks for the reply, and thank you in advance if you can point me in the right direction.
I don't have that issue. Not sure what is going on, but something isn't right. I use Tscam's drivers, however, one thing I learned early on, plug the the interface directly into the motherboard USB port, no hubs, nothing, straight shot.
But really, whatever gets it done for you. Good luck and hopefully we hear some music from you.
Yes sir. I do that. I don't really have issues when I'm by myself, but in a live situation, it ca be annoying,
That might be your HD. If you have a magnetic HD, unless it is a 10K RPM, I could see multiple tracks having issues. If it SSD, then maybe not getting the buffer down low enough. I know I had to finally upgrade my computer when I went to Ableton 11, 10 was struggling, but 11 pretty much done me in. So I upgraded. Lucky for me, I just had to put in a new MB, RAM and I was good to go. But it was still about $700.
I'm using a Dell Latitude laptop. I bought it for a hundred bux or so. I installed a 500MB SSD drive, plugged in 16MB of RAM. The core is an Intel i5. I'm currently running Widows 10. I'm pretty sure it's not the box or the configuration.
What I DID find with Cubase, especially 12, is that Cubase does not play well with the NVIDIA graphics drivers. Indeed, that's why I gave up on CB. I've tried to uninstall, install, reinstall the NVIDIA drives multiple times, as recommended, yet all to no avail.
All that said, my REAL problem is with the R2R. It blows my mind that I can't do multiple tracks. If we record on CH1 and CH2, we can' record CH 3 and CH4 while playing along to CH 1 & 2 simultaneously.
Don, I'm running a I5-4750 Lenovo with 12GB ram and 1TB SSD and a Tascam 16x08 running Reaper. Reaper tends to be a low resource program, so that helps. I've recorded 8 tracks at once and didn't have any issue, but I do direct monitoring. You need to use Tascam's current V4 driver, and you can set it up in the routing page. The driver has been rock solid for me for several years. I run 64 buffer and 88K. The higher rate gives a better latency. V3 drivers sucked, and the first V4 driver was broken, but they fixed it in short order. ASIO4ALL sucked big time when I tried it. Are you trying to use effects through the DAW or just monitoring the inputs without adjustment?
You also need to make sure that you've got your computer set up for max performance. MS likes to set up Windows to be "green" so it turns things down and slows things up, which totally screws up recording.
My other option is a Zoom R-24. I can set up 8 mics, and since there's no USB or computer program running, there's no latency at all. It's also about the size of a laptop, so it's infinitely portable. I use it for recording live jam session. Vocals go into an old Yamaha mixer and feeds 1 channel. 3 channels for drums, one for bass and 3 for guitars is my normal setup. I never know how many guitars will be playing so I go that route. A nice 12 channel snake lets me set up away from the band.
If you want to overdub, you've still got 16 tracks left, and you can pull the SD card, stick it in the computer, dump the tracks into Reaper and work there for mixing, editing, overdubbing.
This was the setup at a jam a few years back. Mixer on the right R24 on the left.
That's a lot of information to unpack. But your setup does seem to solve some problems, What I REALLY want, is to be able to use my Revox R2R in place of your Zoom R-24. I had a TASCAM mixer/recorder that I used for drum recording, but that went south many moons ago (I think I still have it, but, like me, it don't work no mo)
Nice space you got there :)
Hi. I'm Pete.. I'm an Equipment Junkie and I'm about as old school as you get. Analog consoles, reel to reels, outboard, patchbays and enough cabling to wrap around the Earth. at least once. I like knobs, buttons, faders, VU meters and tape spinning at 15 ips and littlelites
Hi I'm ONYX, I've been playing guitar and writing music for 12 years, going to singing lessons for 9 years. I've been in a couple of bands, none of which have stuck. I've recently started my own brain-child and I'm having a lot of fun with my bandmates as we navigate this new project! I prefer to sing and perform - no guitar - but I'm comfortable singing and playing guitar. I have been a professional funeral singer for the past 6 years. People always ask me how I am able to do it - I love everything creepy and weird. Funerals don't make me sad unless I personally knew the person who passed away. It's easy money because I'm getting paid for what I love to do. I'm a barista at Starbucks which helps pay the bills and buys any new equipment that catches my eye. I stopped performing my own set in 2020 due to the pandemic. I am feeling apprehension getting back into it, but since I am getting older and I am tired of being a barista - I have decided to enroll in school. I'm currently going to the Los Angeles Film School for Music Production. I became inspired to pursue production because my cousin is successfully working as a producer, and in 2020 I wanted to take my first steps into recording the music I was writing. I have yet to dip my toes into it. I've recently purchased a lot more storage for my digital devices as a first step into saving my projects online. Currently, all of my projects are living in my notebooks - waiting for the day that they will be recorded. During Christmas in 2023, I cleaned out my parents' storage shed in the hopes of building my own at-home studio. Being enrolled in school will help me fill that studio up with equipment, and I hope to absorb as much knowledge from the members of this forum as I can! I am very fresh to the digital side of music, and I am filled with hope knowing that there is so much out there for me to learn. I am ready to become the best music producer that I can be!
Hi I'm Dave. I've been playing guitar for years and love playing bass, can sing a bit and am only now learning to play keyboards.
Recorded an album a couple of years ago and half way through the 2nd. Self taught at mixing so always looking to improve, and mastering, that's tricky.
I use a 10 year old i7 PC, Windows 10 with 32GB RAM which works seamlessly with Cubase 12, as I generally track through the interface (RME BabyfacePro) zero latency. Probably need a new 'puter soon when Windows 10 bites the dust.
Always looking to improve, help out if I can, and hear what folks are up to.
