Participant: "I own a FMR RNP. It's noisier than my other pres. For acoustic guitar, it flat out sucks. I suspect it would perform similarly on most small diaphram condenser recording applications, where noise is a factor."
I have to disagree with part of this. I agree that the RNP is noisy if you crank the gain all the way up and listen to the self-noise. However, I completely disagree that it sucks on acoustic and other small diaphram applications. I just recorded some acoustic tracks with KM-184s through the RNP, as well as some Hammond organ tracks. I set the gain on the RNP at about 11 o'clock. I'll be damned if I can hear any preamp noise in the track.
Good for you. Stereo mic'ing acoustics as I do, in the ONE room I can use (acoustically treated), mic'ing distance is usually between 12" and 24" (inches). I'm using stereo x/y mc012's. This usually requires at least 36db of gain, giving me a signal that peaks out around -5dbFS. 42db generally clips, unless I mic at least 24" away. It's really a hinderance. It makes it so only certain distances/combinations would work; very little flexibility.
42db of gain makes the noise floor quite loud... I'm sure you hear that.
That said, I've tried a variety of positions... but still no variety of rooms. And a cheap little DMP3 outperformed the RNP in the exact same room.
I'll retract the blanket statement "It sucks on acoustic guitar", because I haven't mic'ed every possible guitar, in every possible room.
Fair enough? I can only offer my experience on the subject. I'm not talking out of my ass.
