B
Bass Jas
Frederic - I was editing my reply when you posted. Check the last paragraph or 2, which should shed some light on why you do not want to disconnect your cold water ground. Jason
Bass Jas said:Frederic - I was editing my reply when you posted. Check the last paragraph or 2, which should shed some light on why you do not want to disconnect your cold water ground. Jason
Damn 3hp motors are EXPENSIVE. I'd rather buy a new mixer. My new planer is in need of a single phase motor......wait.
why don't they call it 2 phase instead of single phase?
Rock on, Local 26 here, did an AOL 2 years ago, data centers suck, I got roped into F/A due to exp. , UPS woulda been more fun, even though quadruple redundant power sources sound boring to most folks!
c7sus said:That may have solved your problem but is illegal as hell...
c7sus said:"....The NEC identifies the "neutral" as the GROUNDED Conductor, while the conductor used to connect equipment or the grounded circuit of a wiring system to a grounding electrode (groundrod, in this case) is called the GROUNDING CONDUCTOR.
Simple, huh?![]()
See! We can agree on something!c7sus said:"...I would suggest before doing any mods at all you consult the 2002 National Electric Code, Article 250. And a licensed electrician wouldn't be a bad idea, either.
c7sus said:It's still illegal. The reference to the NEC applies to ALL services.
QUOTE: "This is the best (easiest) solution to the problem that started this thread. What you are doing is grounding just that room and that circuit."
No, your solution isn't the best. Your solution violates numerous articles of the NEC. Any electrical inspector that would sign off on that solution should have his ass removed.
Read NEC Art. 250.52.(A)(1).
The ARRL has NO jurisdiction over electrical installations.
The NEC covers amature radio transmission and receiving in Article 810. Read Art. 810.58 Grounding Conductors--Amature Transmission and Receiving Stations. This will refer you to Art 810.21.(A) through (J). 810.21.(F) will refer you right back to Art 250.50, 250.52, and 250.94.
Nowhere does the NEC refer you to the ARRL.
The NEC is constantly changing because the technology is constantly changing.
c7sus said:All that post illustrates is that anybody with a website can offer up bad advice.
Beck said:For one, The NEC has no jurisdiction over what a homeowner does himself in his own home as it relates to the subject of this thread.
