Myriad_Rocker
Started on the design on my front wall treatment. Below is the frame for it. The actual treatment itself will cover a bit of the LCD mount (only the 2x4's are shown) so you won't actually see any of the 2x4's at all. I'm going to do that by placing some smaller stock around that part where the depth of that stock isn't as deep. Or I may just paint the 2x4's black and call it good.
This is a 2-piece design. On side goes on and then the other side bumps up to meet it. All of it is mounted with a cleat at the top that will be put on the wall. I'll have a cut out in the treatment at the top to accommodate the single cleat running the length of the treatment. I'll also have a hole at the bottom of one side of the treatment that I'm going to drop wires (to the LCD) down into.
I still have to figure out the logistics of bracing and fabric coverage (with no "seam" lines shown). I figure I'll with that a bit once I see how the insulation is going to fit inside the frame.
Thoughts?
Thoughts?
