How do you have that kick muffled?
Hey Dross...is this the first time, you have used a rack? What is you like about them? Do they hinder your set-up in any way?
right now i just have a small folded blanket laying on the bottom of the shell, but i'll probably have to dampen it a bit more. i can't say for sure until i get a hole cut in the batter head and put my mic in that--right now the kick sound isn't clicky enough--but deep and chesty aplenty!!!
That's how mine was. It boomed like a mofo, but not enough "punch". I put a thin, worn-out pillow that I stole from my dogs inside the kick so it just touches each head. Now it's got a nice deep punch.
excellent, thanks for the tip. it's a pain in the ass to experiment a whole lot with these things, since it means removing the head, putting it back on, and tuning it all over again every time. i'll definitely try your trick next.
You may want to vent your front head. I bought a 4" chrome vent ring kit from GC (10 bucks) on mine. Looks real nice and the hole is small enough that the reso head can still do it's job while a mic fits right in. You can also kinda reach in there and move the pillow around to get the best sound. I tried the pillow up against the batter only, the resonant only, and found that it sounded best in the room - and mic'd up - with it touching both heads just slightly. It also makes it easier to try different tunings with the pillow in different spots without having to take everything apart each time you wanna move the pillow.
I meant the roto's an 8 and 10 inchers. Girly.
yeah, i fully intend to put a hole in mine for mic access anyway. how did you go about cutting yours? someone told me to heat the rim of a coffee can with a propane torch and just set it right on the head, but this sounds like a pretty cockamamie scheme to me. does the kit come with something to cut with?
you totally need a 2nd kick drum to fill that set out to make it look intimidating!
No, you'll need a razor blade or precision knife. The little ring kit I bought is 2 pieces. Theres the ring itself which has a small flange that fits into the hole, and theres another flat ring that slips over the flange portion from behind to reinforce the ring and sandwich the head between the 2 pieces. Both ring pieces have adhesive that stick to the head. I just laid the head on its face, and traced the flange portion of the outer ring onto the inside of the head about 6 inches in from the edge. Then I slowly cut the hole with an X-acto knife. The outer ring slipped right in and stuck in place with the adhesive. Then I snapped the inner reinforcing ring into place and that was it. The whole process took maybe 10 minutes and looks pro. The kit was like 10 bucks. Leave the torch in the garage and the coffee can in the pantry. This was too easy and cheap to not try it.
nah, i had two kicks on my first set (an ugly conglomeration of a 60s gretsch 4-pc and a cheapo mx-80 4-pc or some such crap--i got both kits for $250 when i was 16), and since i switched to a dw5000 double pedal when i got my pearls, i'll never look back. although i must say my new iron cobra seems far superior to the dw, even though most people tell me i'm crazy...
besides, i'd have to pay an extra $742 for the 2nd one!!!
I agree that my Iron cobra single pedal is way better than the dw and people tell me Im crazy also. But once I adjusted it to where I want it and spent some time working I find it waaaaayyyaaayayaya better!!
