T
taylorguitarman
I've been putting together my studio again now that I have a house and can dedicate some space to it and I'm in the process of getting everything cabled up when I've learned my first lesson of you get what you pay for. Once I got everything setup I wanted to test a mic through my fancy new patchbay. I didn't get many XLR->TRS cables since I'd planned on using a snake box for the mic inputs but I figured I'd hook everything into the patchbay and see how it worked. So I had a slightly older Hosa cable that had the right connectors and gave it a shot. Ground noise. Oh crap. Everytime I let of the connector I'd get noise. I had a 6' Mogami cable that I'd just bought but was going to exchance if everything worked OK for a longer one but I had to find out if it was the cable. Sure enough I plugged in the Mogami cable and quiet. So I've finally encountered my first bad cable.
If the noise went away every time I touched the connector could it just be a bad solder/connector? Could I salvage the cable by getting new connectors or resoldering the existing ones or is the cable toast?
I bet you will find a loose wire when you open the connector up.
