Multiple tracks with the digi 002 rack.
  • Thread starter Thread starter jamesheater1
J
jamesheater1
How do you record more than 6 tracks with the digi.. After you record 6 tracks then what do you do to record more for the same song?
track => new
then set the input's on the new track's that appear to the corresponding inputs that you're using for the new tracks.
hope that answers your question.
Well, there's 2 ways. The first is to just create new tracks for the same session , up to 32, or, you can use the onboard pres on channels 1-4, 4 channels of outboard pres on channels 5-8, an 8 channel pre w/ optical ADAT out, such as Behringer ADA8000 or M-Audio Octopre for 8 more channels, and for good measure, a 2 channel pre with coaxial S/PDIF out for 2 more. This gives you a total of 18 simultaneous inputs. In Pro Tools, use "new track", which will create as many tracks as you want, uto 32. Then use I/O to route the new tracks to the appropriate inputs. Bennychoi will be along in a while to tell you more. He's a real expert. Good luck-Richie
Snowman999
Replies
13
Views
2K
Papanate
Papanate
B
Replies
1
Views
290
rob aylestone
rob aylestone
Consfow
Replies
9
Views
627
LoopMastering
L
R
Replies
34
Views
2K
Papanate
Papanate
