Pro Tools M-Powered 7.0 for M-Audio Systems on Windows XP
Pro Tools M-Powered 7.0 compatibility
* Windows XP Professional or Home Edition
* Not Supported:
- Windows XP Professional x64 Edition
- Windows XP Media Center Edition
* Pro Tools M-Powered 7 is qualified with Windows XP Service Pack 2 (SP1 not tested)
* Pro Tools M-Powered 7 software can't be installed or used on systems running Windows 98, Me, 2000, NT, 95, or 3.1
M-Audio Hardware Supported by Pro Tools M-Powered Software
Pro Tools M-Powered software requires one of the following M-Audio Interfaces:
* Audiophile 192
High-Definition 4-In/4-Out Audio Card (PCI) with Digital I/O and MIDI
* Audiophile 2496
4-In/4-Out Audio Card (PCI) with MIDI and Digital I/O
* Audiophile USB **
USB Audio/MIDI Interface with Digital I/O
* Delta 44
Professional 4-In/4-Out Audio Card (PCI)
* Delta 66
Professional 6-In/6-Out Audio Card (PCI) with Digital I/O
* Delta 1010
10-In/10-Out PCI/Rack Digital Recording System with MIDI and Digital I/O
* Delta 1010LT
10-In/10-Out PCI Virtual Studio
* Fast Track Pro **
4 x 4 Mobile USB Audio/MIDI Interface with Preamps
* Fast Track USB *
Record Guitar and Vocals on Your Computer - Complete with Effects
* FireWire 1814
18-in/14-out FireWire Audio/MIDI Interface w/ADAT Lightpipe
* FireWire 410
4-In/10-Out FireWire Audio/MIDI Mobile Recording Interface
* FireWire Audiophile
4-In/6-Out FireWire Audio/MIDI Interface
* FireWire Solo
FireWire Mobile Audio Interface for Songwriter/Guitarists
JamLab **
Personal Guitar System
M-Audio Black Box *
Amps | Effects | Drums | Recording USB Audio interface for Guitarists
* M-Audio Ozone *
USB Audio/MIDI Mobile Workstation
* MobilePre USB *
USB Bus-Powered Preamp and Audio Interface
* Ozonic
37-Key FireWire Audio/MIDI Interface and Controller
* ProjectMix I/O *
Control Surface with Motorized Faders and 18 x 14 Audio Interface
* Transit
High-Resolution Mobile Audio Interface
*Pro Tools M-Powered 7.0 or higher required
**Pro Tools M-Powered 7.1 or higher required
About Pro Tools M-Powered Software
* Pro Tools M-Powered software requires one of the above M-Audio hardware devices, which must be connected to your computer to run Pro Tools M-Powered software
Pro Tools M-Powered supports the use of any single supported M-Audio peripheral. Simultaneous use of multiple M-Audio peripherals is not supported.
* Other audio interfaces from M-Audio have not been qualified with M-Powered
* Audio interfaces by Digidesign or any manufacturer other than M-Audio will not work with Pro Tools M-Powered software
Authorization
* A pre-authorized cross-platform (Mac/Win) red iLok USB hardware key is included with all Pro Tools M-Powered software purchases
The Pro Tools M-Powered authorization works with all versions of Pro Tools M-Powered (6.8, 7.0, 7.1)
Total System RAM
* 512MB minimum required for Pro Tools M-Powered 7, more recommended
* More RAM increases overall system and Pro Tools performance
* More RAM suggested for sessions with high edit density, extensive use of plug-ins, or simultaneous use with MIDI sequencers
* 1GB total system RAM or more required with Music Production Toolkit option in order to reliably achieve maximum track count
* Refer to motherboard manufacturer for supported RAM version
Additional Requirements
Monitor
* Minimum resolution of 1024 x 768
* 17" or larger recommended if using external monitor
Performance Guidelines
* Recording to the system startup drive is not recommended or supported
* Although limited recording and playback of audio tracks may be possible using the startup drive, one or more separate dedicated 7200 rpm audio hard drive(s) is required for maximum performance and track count
* Dual processor machines may need to have network cards disabled for best performance
Known Issues
* Pro Tools does not support RAID technology. Please do not activate this feature on any Pro Tools recording drives.
* Computers with motherboards containing SiS (Silicon Integrated Systems) chipsets
* Intel Celeron, Pentium III and older processor based computers are not supported
* AMD K6, K6-2 or K6-III, K7 processor based computers are not supported (newer AMD Athlon XP, Athlon 64, and Athlon 64 FX processors are supported)
* Before purchasing these or any computer, please carefully go over these documents and the exact specifications of the computer to make certain that all of the compatibility guidelines have been met.
Music Production Toolkit Option — Maximum Track Count Information
The purchase of this option expands a Pro Tools M-Powered system from 32 total voiceable tracks to up to 48 mono or 48 stereo tracks at up to 96 kHz (interface permitting). Some laptops are capable of 48 stereo tracks at up to 96k, providing the system meets the following recommended requirements for maximum track count:
* 2GHz or higher processor
* 2 or more hard drives dedicated for audio record and playback:
- 2 or more external FireWire drives (7200 rpm)
M-Audio Driver Updates
To download driver updates from the M-Audio website:
* Go to the Support-> Drivers section on the M-Audio website.
For more information, visit this page.
