F
fgonza2
switching the tracks off is as good.
Just wondering..Why the manual doesn't mention the fact that DBX should be switched off.
Lastly, Does the recorder have to be in the "Record Ready" state at anytime (like the manual says) to do these adj.?
I've already erased 3-4 seconds of cal. tape!![]()
Sorry, a lot of firsts and unknowns here. But, if you'll be patient with me here? I am so grateful for your help.Thanks for the suggestions fgonza2. I don't know where the problem was. I moved the generator and RMS meter and plugged them both into a different power supply. I also used two separate RCA's rather than the two connected 1white/1red type cable. the problem went away. So hurray! generator good..RMS good.
I re-calibrated the recorder. Everything great in SYNC and REPRO @ 1kHz and 10kHz.
Everything great in SYNC @ 10kHz. REPRO All is great (exception)
Trk 1 -2 on VU -12 on RMS
Trk 10 -1.5 on VU -11.5 on RMS
Trk 16 -3 on VU -12 on RMS
So I'd say much better.
Remember to the scope part and the ellipse... we discussed that one like 50 posts ago or so.
NO0. Make sure to calibrate playback levels first with the calibration tape (both repro and sync head)
1. Put them in GND mode
2. Use the position knob (vertical) to make sure the ground is at zero. Not trigger, dont change anything in there.
3. Ok to not disconnect if you use the GND mode.
4. Do this for both channels
5. Yes .1 on the dial
6. After this go to XY mode
7. Yes, change in the test tape from 1khz to 10khz
8. As suggested by jpmorris, you can use the generator first and connect it to inputs 2 and 15, then put it in input monitor mode, and you should see a perfect 45 degree line (make sure the generator output is at 0.3V rms), so you can make sure the setup is correct. If it is not 45 then your levels are off somewhere either on the generator or in the input circuitry calibration. (post picture)
9. After that switch to repro mode and you will see the ellipse (with the 1khz tone it will be nicer) look at it with 10Khz and 16khz tones on the tape, post pictures.
10. Repeat with sync head
I can see the pictures nowlet us know how it goes. Did you setup levels already ? how did you measured it ?
