ok, some questions:
1. Do you see the same behavior on all channels ? (on SYNC)
2. What is your calibration tape ? 355 nwb/m ? is it a new tape ? what is the condition ? where did it came from ?
The 30 ips mod has no impact. It should work fine. Try the following:
1. Find a channel on either SYNC or REPRO that gives you a good reading, if any.
2. Turn off the recorder and swap the card of that channel with another one that is not working well.
3. Test again and see if the behavior follows the card that you swapped (in the new channel)
Report back, if the behavior is the same or not. If the new channel is now good, it means it is electronics adjustment, if it's not good and the problems are identical regardless if you swap the channel cards or not, it means you have a mechanical issue (head not aligned properly)
report back with findings
