A
AnnieJohnson
Hi All,
I am trying to adjust Record and Playback heads on my Teac A-3340 but do not have access to any test tapes.
I do have the following equipment:
1. Audio frequency oscillator
2. Oscilloscope
3. An AKAI X5000 (which has its heads in original and perfect condition)
I wonder if someone who has more experience can read and confirm if I am using the correct approach.
To adjust Playback head:
1. Record a test tape (using 15 KHz signal) on AKAI which is 2 channels only.
2. Reverse the tape (as if I was recording side B of the cassette) and record the same 15 KHz signal using my Akai.
3. All 4 channels on the tape now contain 15 KHz tone.
4. Load this tape on Teac A-3340.
5. Connect 10Kohm resistor as the output terminals (output 1 and 4 as they are at the two opposite ends of playback head).
6. Connect oscilloscope on output channel 1 and channel 4 of Teac and make adjustment to Azimuth (as per the manual)
Repeat the same with 10 KHz tone.
Will this procedure work or help with playback head adjustment?
Regards
Annie
2. Oscilloscope
Regards
Annie
