virtualvisions
Euphonix rocks
I'm probably missing some really basic concept thinking up this idea, and putting aside any practicality criticism (I just wanna know if this would work
) I was thinking of way to make an MS recording using 3 cardioid mics.
An MS recording with 2 mics is 1 cardioid and 1 figure 8. The left signal is the positive left mic signal, the negative right mic signal (from the negative side of the figure 8) plus the mid mic. The right signal is then the positive right mic signal, the negative left mic signal, plus the mid mic.
I was thinking, using 3 cardioid mics, one would be the mid, and then 2 other cardioid mics would be the left and the right (they would be facing away from each other at 180 degrees). The left would become the mid mic, plus the left mic minus the right mic, and then the right would just be the mid mic, plus the right mic minus the lef mict.
The only real difference would be that the right and left mic signals wouldn't be in the same space as they would be with the figure 8, so the only potential problem I can think of right now would be phase issues, but maybe if the left and right mics were close enough together it might work?
) I was thinking of way to make an MS recording using 3 cardioid mics.An MS recording with 2 mics is 1 cardioid and 1 figure 8. The left signal is the positive left mic signal, the negative right mic signal (from the negative side of the figure 8) plus the mid mic. The right signal is then the positive right mic signal, the negative left mic signal, plus the mid mic.
If the side mikes were omnis, they would basically pick up the same signal, neglecting directionality at high frequencies. Mathematically, the omni response, as a function of angle, a, is: response = 1. So, if you take the difference of L and R pointing mikes you get 1 - 1 = 0 or total cancellation. All you would hear would be the high end information along the axes.
