M
moriluk
Why is the standard consensus that 4 track recording yields 7 tracks? Other than fidelity, what is preventing infinite track bouncing?
In other words, the standard method is this; record 1, 2, & 3. Now what? Bounce them to track 4. And then you record 1 & 2 again then bounce them to 3, leaving you with up to 7 tracks on a 4 track.
But if you can bounce 1 - 3 on 4 and so forth, why can't you then bounce tracks 3 & 4 to track 1? And then record 2 and 3 and bounce all those to 4 again and keep repeating the process.
For simplification:
track 1 (a)
2 (b)
3 (c)
bounced - 4 (abc)
record again, track 1 (d), 2 (e) bounce them to 3(de).
now you have 3 (de) and 4 (abc). If I can bounce 1 - 3 to 4, why can't I bounce 3 & 4 to 1?
now you have track 1 (abcde),. then record track 2 (f) and 3 (g). repeat process (track 4 = abcdefg) leaving 1 - 3 open again?
If the answer is fidelity that is understandable, but fidelity is an issue in the first place, this does not mean that you are limited to 7 tracks with a 4 track.
I will probably skip all of this and just mix 4 tracks to CDR and then record that to a new tape.
For simplification:
track 1 (a)
2 (b)
3 (c)
bounced - 4 (abc)
