bouldersoundguy
could someone hit me with some watt/ohm knowledge?
If the amp is 50w at 4 ohm and 80w at 8 ohm...my speakers are 6 ohm, how do I figure the amp wattage? Or in general how do I figure amp wattages.
I've also got an old amp of my dad's I'm going to be using for a bit and it says 4 ohm 125w (which is enough for me for now) but how do I figure out what it is at 6 ohms, just out of curiosity?
thanks
Lowering impedance increases the power drawn. But it's not always a simple thing because thermal limits become important as you lower the impedance.
In the first example it's likely you got the impedances and powers mixed up. The power for 6ohms would be between the 4 and 8 ohm ratings. So for an amp that did 50 watts at 8 ohms and 80 watts at 4 ohms the 6 ohm output would be about 65 watts.
The 125W@4ohm amp would probably do about 70W@8ohm and about 100W@6ohm.
