no no no
yer mixing this up with mic modelling, this isn't about making a sm57 sound like a neuman, it is about hooking up your SP or MXL or whatever to a preamp unit and saying  I want an approximation of a Joe Meek, or a Grace or an Avalon, just like a POD makes your axe sound like it is coming through a Marshall, or a Vox AC30, or
a Fender 65 Blackface twin, PODs don't make your Squier sound like a Les Paul, and this thing I was talkign about won't make a 57 sound like a Neuman.
I agree that mic modelling is a flawed concept, you can't make a mic sound like something else when they have entirely different sensitivities and the physical one you are using simply doesn't capture the sounds the one you are modelling would. An amp (like in PODs) or a preamp is an entirely different matter for modelling, It is about signal modification post-mic, and that is something that has already been proven with guitar amps and bass amps as a decent technology.
I know that a lot of people argue that amp modelling for guitars doesn't sound like the real thing, I agree, but it does sound nice and having a bunch of models of preamps would be an interesting concept. In fact, I think preamp modelling has more of a basis to suceed.
Guitar amp modelling largely fails to be utterly convincing because with real amps there is a physical interaction of the amplified signal (from teh speakers) with the object making the signal (guitar body/strings/pickups). When you are hooked up with headphones, it just isn't quite the same. And if you record a dry signal of a guitar and run it through an amp after the fact so that there is no longer a real guitar in the equation it sounds different: try it.  Just like if you hook a guitar up to a POD, but using a Y cable also run a line straight from your guitar to any amp so that there is a noise-field for the guitar to operate in, you will find the POD emulation sounds better and more convincing. Again: try it.
BUT with preamps and mics going direct into a mixer and into a recording  device there is no interaction between the amplified signal and the object creating the signal.
I therefore think that preamp modelling actually has more potential than amp modelling based on this. Would it sound exactly like you are using an Avalon, or a Grace? not exactly. But will it sound better than your VLZ Pros....I think it would and am curious to see one of these devices.
