T
The Ghost of FM
Banned
Hi,
Of course I want a mixer that can compliment the analog sound of the 38. But I also wouldnt mind a new mixer if it does just what i need and nothing extra fancy.
To answer your questions...
1.
Mainly 1-2 with the most ever being 4-6 for drums. And there I can compromise if I had to.
2.
Mostly just me. But occasionally I will be with someone...
OK, now I have a little bit more to go on!
Recording drums when you only have 8 tracks to play with on the 38 will probably force you into initially not using more then 4 tracks of tape to capture them, basically, kick, snare/hats and a stereo overhead pair and once you get a good mic setup down, you could probably squeeze that down to just 2 tracks of tape with a good sub mix set up on your mixer so the mixer I mentioned in my last post, the M312B would still be flexible enough to handle all of that.
As far as new mixers go you'll probably have to look strictly at the Mackie's and need to get one with direct outs and at least 4 recording busses. The Mackie's wont sound as warm and smooth as the older TASCAM's would but they would be newer with less chance of service issues for the here and now anyway.
Cheers!
