H
Harvey Gerst
So, Grasshopper, you wish to become a Shou Lin priest of audio? First, you must try to pluck the pebble from my hand. You cannot do it? This is your first lesson; things are not always what they appear to be.chessrock said:So what's the word on the API's we're talking about. I know you tend to be partial to the Great River in terms of value, so how would one of these single channels compare?
The API 212L is the preamp module out of an API console. Most professional consoles are made up of channel strips or modules than can be removed and still have the other parts of the console function. The API module has a special connector on the end of the module which carries the balanced signal, in, the balanced signal out, and the power lines connections that are needed to power the module.
That price is for the module only. To make it talk to the real world, you need the other stuff, too. That's usually called a "lunchbox" or a rack supply. It has the XLRs i/o's and built-in power supply that is needed to power these modules. Guess what? That's another $800, but it will handle four of these API modules.
That means that a single $625 212L mic pre (with the $800 four bay rack mount power supply) will cost you $1,425. A pair of 212s will cost you $1250 PLUS $800 (for the four bay rack with power supply), for a total of $2,050.
But you say that the 12 channel rack is only $625? Yes, but that does not include the power supply, which is another $750.
Why the sad face, Grasshopper? You are learning, but it will take time.
