H
Harvey Gerst
I've seen this question posted here over and over:
"Do I need to used matched microphones for stereo recording?" or "Can I use two different microphones to record my acoustic guitar?". I thought it might be nice to clear the air and a few misconceptions at the same time.
"Stereo" is a very precise term, used to define the recording of something in spatial terms. Just because you use two mics to record something, it will come out "stereo". In many cases, you're just recording two different frequency ranges and separating them into left and right signals, but that's not stereo.
When you use two different mics (or two identical mics, for that matter) in close to record two different places on the same instrument, that is not stereo.
Stereo recordings require the use of two matched microphones, placed outside the near field, to create the illusion of the instrument in its natural environment. The placement can be coincident, near coincident, M/S, or A-B spacing to capture the acoustic space.
This use of matched mics and specific placement techniques is done to maintain the stereo integrity of the signal at all frequencies.
If you ain't doing that, you ain't really recording in "stereo". You can, for example, put one mic in close on an acoustic and position another mic a lot further back, but it ain't stereo. It may be flattering and it may sound great, bit it's not stereo in the strict sense of the word.
What you're doing is breaking the signal into two different ranges and recombining them in the mix to get a bigger, or fuller, or fatter sound, or whatever. But it's not stereo. It's a valid, but different technique.
If you want a two channel recording of your acoustic guitar, you can record with two different mics placed in whatever places sound best. If you want a true stereo recording of that instrument, you'll need two identical, closely matched mics, placed in the usual stereo recording placements.
I just want to understand where this recording definition of "stereo" came from and, more importantly, why it means what it does.
