harley96
I wanted to know do you peg the meters well up into the yellow on the masterlink and an occasional red will that digitally distort? Do you use any of the dsp internally on the masterlink or do you tend to use outboard gear. I know the compressor is designed obviously to compress the whole mix as a whole and if you were going to use it , what kind of threshold, ratio, release, would you use without adverse effects on the mix. I know every project has different elements to take in consideration when using dynamic processing but as a whole could you give me a good starting point. Thanks,Greg
