Mastering to Analog
  • Thread starter Thread starter Bguzaldo
Two more questions...sorry!
Is this the tape you said will work for the RS-1700 and is it 10.5" or 7" cuz I've seen this tape in both sizes.
http://protape.stores.yahoo.net/rmgism91114.html
And If I had say a 10.5" supply reel do I need a 10.5" take up reel? or could I have like a 7" and a 10.5".
Again Thanks so much
-Barrett
Beautiful! Thank you so much, I just got the Technics reel to reel (she's a beaut) and that was the one thing I was waiting on before i can start!
Thanks so much
-Barrett
Not sure if anyone remembers this thread! But I finally got the machine up and running and I did the A/B comparison! I'll post it as soon as I can
Hang in there!
-Barrett
I would try backing off on the compression on the mix - especially the drums, then hitting the tape again. Watch your tape levels - they sound a little too hot.
Have you cleaned the tape heads? There's a lot more high frequency loss than I think there should be.
Haha Yeah I kind of have a big compression issue, but I'll give it a try and yeah I did clean the heads with a Q-tip and some rubbing alcohol when I got the machine is that enough?
Thanks for all the help, I'll re-post the less compressed tape version as soon as I can.
-Barrett
You MUST demagnetize the heads as well. I will let Cory and others speak up as to currently available demags wnds; apparently there are some cheapos out there that don't do a good job.
AK
AK
Are you saying this as a general rule of thumbs or can you tell that my heads need to be demagnatized?
Thanks for the reply!
-Barrett
