Even if bypass the limiter circuit in the Spider, part of it is still there, that circuit doesn't exist in
the HEDD-192.  If you come into the Spider "line in" you're going through the 'line in amplifier'... if you come in through the 'insert point', you're still going through part of the limiter... in other words you have "similar" yet not exact paths on which the audio travels when you go from one to the other.
Another subtly significant difference be is that the board layout is different between Spider and HEDD... this creates different 'interaction between components'... which will result in a different tone [no shit, ask Dave].
To me, the HEDD-192 sounds a bit 'softer' [not in a bad way... just the only words I can grab for a description] than the Spider [that is just 'converter to converter... no processing involved of any kind]... but then again I've actually listened to the shit side by side and asked 'how come this sounds different'... which I reckon you ain't done...
Yes, the two units do indeed use the same converter chips... but most of the converters out there use the same chips.  The tones and textures provided by converters are provided in the analog circuitry and the clocking... with
major emphasis on the liniarity and headroom of the power supply.
Pimping is pimping is pimping is pimping... call it what you will... but to speak in absolutes about
anything you haven't heard, worked with, experienced for yourself is just fuckin' pimping.
FWIW... in April a discussion came up on PSW about Benchmark's impending release of the "ADC-1" [which still ain't out BTW]... following is a 'response' to a query about the unit... this is from April, long before this little dick measuring fest...
On 22 Apr 2003 06:14 fletcher wrote:
			The current 1/2 rack A/D converter they have is absolutely killer!!  The DAC-1 is absolutely killer... if this thing is a new model that comes in somewhere between the two on price... it could change a whole lot 'standards of the industry'!!
As you can see, this not "talking in absolutes" isn't a new creation devised for the moment... it's been an ongoing thing since day fucking one... so, what's my point?  My point is that it's kinda shitty to talk out of your ass if you don't have the experience... that's the point.
We gonna go another round or two on this?  Your call... and frankly you can get a day or two of "the upper hand" as I have to leave in an hour or so to testify as a 'expert witness'  in a NJ courtroom...
