Starstreams
Member
Maybe I’m over analyzing this but on this new t.c.electronic M-One XL, the display seems to work fine meaning all the numbers are sharp and light up bright. But if you look at the display at certain angles it almost looks like you can see a led light in the center. Now I know there is fosper material that transfers the light on the back display but should it be even across or is it normal on some units to see a very slight deviance in brightness on the back display panel? This is not affecting the letters or numbers in the display, just the back display itself. Kind of hard to explain I guess. It almost looks like there is grease on that chalky material that makes up the background of the display yet the letter names all light up even and bright.
