I happened upon a pair of Kepex Valley People gates. Now I'm trying to install them into my system and I ran into a problem. I've been getting distorted, ungated output when my patch is solidly inserted. When I pull the patch cable out a bit, I get a normal gated output.
The ins and outs of the units are the screw-in wire type (no 1/4" or xlr). The input is pretty standard; it has a hot, a cold and a ground. However, the output has a single screw for hot/cold and then a screw for ground. I traced my cable back and discovered that the hot and cold are soldered to their standard tip/ring positions. I have a feeling this is my problem. Should I toss a jumper between the tip and ring solder points? Should only hot OR cold be used, thus creating an unbalanced output (as opposed to the clearly balanced ins)?
Your aid and expertise are greatly appreciated.
