Intersound 8 by 1 mixer
  • Thread starter Thread starter slayer814
slayer814
I am trying to find a manual for a Intersound 8 by 1 mixer. I have searched google and can't find a manual. Any help would be appreciated. Thanks.
I am new to this type of thing and need the manual. I got it from a friend of mine who said he didn't even know if it worked. I plugged it in and no smoke or sparks and my hair didn't stand up straight, So far so good.
What are you trying to do with it, as said before, it is pretty straight forward. although not sure what the echo jacks are for. maybe we can help. :D
Basically, I just wanted to see if it works. I will probably end up selling it for $50.00. But I don't want to sell something unless I know it works. I play guitar and use a digitech gnx4 multi effects with built in 8 track recorder and drum machine.
That info is very helpful, Thank you. I will try hooking it up tomorrow.
If you have a guitar amp with Send and Return jacks you could run a cable from the -10dB Main Out on the mixer to the Return jack on the guitar amp. Plug your guitar into a Hi-Z input jack on the mixer and slowly bring up the Volume on that channel. Set the Master maybe about 12 o'clock for starters. The Hi-Z input may have enough gain for a guitar (maybe). If you have a guitar amp that doesn't have Send/Return jacks, then try the main guitar amp input with a volume set really low to begin with. Try each channel the same way.
You could play a bit with the reverb controls, but I think the reverb may an external unit. If you give the mixer a bit of a light whack and you hear a springy boing noise from the amp, it's got a spring reverb inside it.
loved the wack comment, I had a mixer years ago that had the spring reverb in it. that was always a quick way to see if it was working:laughings:
Inside Pics
IMG_20150715_175507.webpIMG_20150715_175502.webpThank's for all your help. Here are pictures of the inside of the unit. I think it does have the reverb spring inside.
