slayer814
I am trying to find a manual for a Intersound 8 by 1 mixer. I have searched google and can't find a manual. Any help would be appreciated. Thanks.
I am new to this type of thing and need the manual. I got it from a friend of mine who said he didn't even know if it worked. I plugged it in and no smoke or sparks and my hair didn't stand up straight, So far so good.
If you have a guitar amp with Send and Return jacks you could run a cable from the -10dB Main Out on the mixer to the Return jack on the guitar amp. Plug your guitar into a Hi-Z input jack on the mixer and slowly bring up the Volume on that channel. Set the Master maybe about 12 o'clock for starters. The Hi-Z input may have enough gain for a guitar (maybe). If you have a guitar amp that doesn't have Send/Return jacks, then try the main guitar amp input with a volume set really low to begin with. Try each channel the same way.
You could play a bit with the reverb controls, but I think the reverb may an external unit. If you give the mixer a bit of a light whack and you hear a springy boing noise from the amp, it's got a spring reverb inside it.
