B
bgavin
Intel chipsets for gaming (for sure).
AMD for everything else that isn't specifically written for an Intel chipset.
Avoid VIA chipset boards. The nForce boards are faster and more stable. VIA has an endless stream of hardware/driver issues, that they resolve by releasing yet another version of the chipset.
All processors run hot. Invest in a heavy duty one (Alpha PAL8045, etc) that mounts to the board using the 4-hole mounting system. Avoid heavy heat sinks that clip to the processor socket. AMD specifies 300 grams max, and the big boys are much heavier than this.
The Asus and ABit nForce boards have the 4-hole mounting system, but many of the nForce boards do not. These two are my personal choice. If you go nForce, be sure to buy two sticks of memory to use the Dual Controller feature. It is free performance built into the nForce chipset. Buy an absolute minimum of 512mb total memory if using XP. A gigabyte is better, and XP will use all of it.
The Panaflo Ultra fans are the highest CFM fans that are still quiet. I use the H1A models satisfactorily with the PAL8045 heat sinks. The H1U higher output fans will cool a bit more.
