Important Tape Calibration Question
  • Thread starter Thread starter thereelman77
Aren't they inaccurate over 400Hz?
they are innacurate above 120Hz in most cases of the cheap ones. Any DVM or voltmeter won't do it. It has to be a trueRMS with proper frequency range. The best bet is the leader LMV-181A, i bought mine for $40 and it is a great unit for this.
I have one of the upper-end Radio Shack DVM units (can't recall the model at the moment)...it was maybe $70(?) about 7-8 years ago...it's accurate, and also reads in dBm.
yes they exist. but not the standard for cheap DVMs. Too many people end up buying $20 DVMs assuming they can do TrueRMS up to 20 kHz. Always good to check the specs to make sure it is the case like in yours.
The one I had before I got the Fluke was only good up to 400Hz. Sadly I had to buy the thing first in order to find that out because it was buried deep inside the manual.
Ah good point, I rescind my suggestion there, I forgot about the cheapies being inaccurate above lower mids, but yeah, $40 can get a good DVOM, not all are created equal and yes you need to check the specs. It's a good general purpose piece of equipment to have in life anyway, as basic a toolbox item as hammers and screwdrivers IMHO.
This is what it is.
So....What should I do. Because I'm trying to save for 1/4" MRL? Will that device be sufficient enough?
I might be a little hard to read on that analog meter being that the reference voltage for -10db gear is pretty low. Dial the meter to 10 AC V it and see what you get at 1k then lower the tone to something like 100hz while keeping the tone's level the same and see if you get a very different reading. Interesting that it has a dB scale. Try your meter and and see what you get.
By the way, how is your machine SOUNDING now? Better, more consistent?
The machine is sounding better. It is more consistent. I have noticed that the "low end" buzz from the machine seems to be a bit louder than before, but I assume that, that is because it is actually calibrated.
Do you mean a 60hz ground hum? Does your machine have a head shield? How long is your cabling?
Well it could be a 60hz ground hum, now that you mention it. It's really only noticeable when the deck is in standby. And we also built the wooden stand with it on a slight slant, would that affect it? We built it so that it's basically level when a person is sitting down in front of them. I'd say about 2 & 3/4' to 3' up. Cabling is whatever they built the plug to, 2/3 feet or whatever. Never used a extension cord with it. Plug it into a power strip most of the time, sometimes into a separate outlet from the wall.
As far as a head a shield, it has the one that lifts up & down for access for head maintenance, but if you mean does it have a shield in front of the heads, then no...
Part of it sounds like a 60hz ground hum, but the rest just sounds like noise from the deck.
