Well it could be a 60hz ground hum, now that you mention it. It's really only noticeable when the deck is in standby. And we also built the wooden stand with it on a slight slant, would that affect it? We built it so that it's basically level when a person is sitting down in front of them. I'd say about 2 & 3/4' to 3' up. Cabling is whatever they built the plug to, 2/3 feet or whatever. Never used a extension cord with it. Plug it into a power strip most of the time, sometimes into a separate outlet from the wall.
As far as a head a shield, it has the one that lifts up & down for access for head maintenance, but if you mean does it have a shield in front of the heads, then no...
Part of it sounds like a 60hz ground hum, but the rest just sounds like noise from the deck.
