I'm not sure but I have an old Teisco (late 60s) that has one that looks very similar. Is the lower (wood) part free on yours? Mine just sits on the body.
no other purpose ..... it just keeps the screws and saddles from falling off if there's no string on them. You could wedge something in there or you could bend that spring so it would hold itself in place more firmly or you could even remove it, which I did on one of my early Pauls although then every time you changed strings you'd curse and wail about the saddles falling off.
ID This Bridge...
Its an standard archtop floating bridge with hight adjuster wheels and a tun-o-matic on top.
See Stewmac for a description of various archtop bridges.
Archtop bridges
Do you suppose those are decent bridges? I am (as mentioned above) looking to replace my fixed-intonation, adjustable height archtop bridge with a T-O-M, and the price is right![]()
You going to sacrifice quite a bit of tone and harmonic attack if you switch from a solid wood bridge to one with a lump of die cast metal on top. I would investigate why you have an issue with the intonation first. Is that G string intonation wrong even with new strings? Does it get worse as the strings wear? The bridge on a archtop is critical to the acoustic tone so any change is potentially significant for better or worse.
A couple of important considerations with archtop bridges for you. The foot of the bridge should make perfect contact with the top all along its length. The angle should be at 90 degrees in front of the bridge and the top. The bridge does not have to sit parallel to the nut it can and often needs a little relief to set the intonation correctly. The normal centre is between the "nicks" of the f holes if it has them.
One of the advantages of archtop floating bridges is that you can swap them out without too much trouble. Be careful of the finish if you do swap them about. If you interested in trying out a few I can let you have some more in depth tips on correct fitting.
My question is: There's a small wire that holds the intonating screws in place. It's rattling, and IT MUST BE STOPPED!!
Does that wire serve any other purpose? Can I just wedge something in there to keep it from vibrating?
Put a drop or 2 of Elmer's glue on them. If you need to adjust the intonation the glue will just peel off.
because they usually need the most adjustment in that direction for those strings. So the flat side of the saddle will get the furthest forward or rearward depending on which way it's turned.
