RecordingMaster
A Sarcastic Statement
In my mind, recording/mixing is alllll about commitment. People are too scared these days to make a commitment. They record dry, and then they leave CPU intensive plugins active across their whole session for fear of needing to go back and tweak it later in the mix. My theory is, yes, adjust your otb gear with the whole mix up (not in solo), but get it to it's sweet spot and print that damn thang! Then move on. Guess what? You'll finish more tracks faster that way rather than fussing about for days on end about the Slate VTM tape setting (for example) you put on your bass track!
Lately, I believe in printing all the stuff you know sounds good like a setting you found on an otb comp, amp sim, drum trigger, or a tape saturation setting on a track, and only having up the core plugins you should be actually concerned about tweaking down the line in mixing that will make a discernible difference, like channel strips on all your tracks as well as the plugins/otb gear on your parallel sends.
Commit! And move on!
I grew up on 4-tracks too, and I still use the Tascam 246 for some songs.
