B
bpape
Acoustic Designer - GIK
Yes. Those wooden ones are membrane absorbers. They must be sealed air tight with caulk all around in addition to the top and bottom. You also can't have the front plywood touch anything but the frame.
They work by using the trapped air in the cavity as a spring to damp the wood vibrating and have the 703 help to absorb it and make the space appear acoustically larger.
Understand that the wood panels like that will function over about an octave or 2. The thick 703 will function over many octaves. All a matter of what you need.
Bryan
Bryan
