C
		circlemouth
I'm using a Shure SM-57 with an Art MP Preamp into a Roland 840ex digital multitracker.  I didn't notice it before, but it seems like recently I'm getting a lot more of a hiss than I used to.  (The only thing I can think of that may have caused this is I put the wrong power adapter into the preamp once and it freaked out a little bit.  Then again, I'm not that perceptive--the noise may have been there all along.)  It is only a slight hiss, I'm in a tiny apartment and part of it may be the hum from variance electric devices and appliances.  When I transfer my recordings onto computer I have some programs that can clean this up but until then (and more preferable) what ways can I
I suspect I'm not setting my levels correctly. There's not only the input dial and mixing knob on the 8-track but the input/output on the the preamp. Generally, what's the suggested setup for these? Right now I just have the preamp dials set right in the middle and the input on the 8-track just high enough that it doesn't clip (maybe around -40 db) and mixer knob at around -4 db. Should I set the input on the preamp a little higher and a little less on the 8-track, or vice versa? More output? Less? I have no idea how to arrange these. I appreciate any input (I don't clip)...Thanks....
