RideTheCrash
Member
Okay, I haven't been on this site in so long, but now that I have a part time job, and some cash coming in, I can seriously start figuring out my setup. Now mind you, I'm only 17 and don't need anything overally fancy.
I have a 16 channel Audiopro board (old one from the 80s, Yorkville doesn't make anymore). I'm looking at purchasing a Delta 44 (just 'cause the 1010 is a bit pricy for me) and am trying to figure this whole thing out in my head here. Basically I have Cool Edit 2 and want to be able to record, say, 4 mics on a drumkit, and have them run into separate tracks on the program, correct? (Provided I had the Delta).
If so, could I play the tracks on the software, and have them playback through the channels on my board, so I could physically mix on my board instead of moving lines around on the software? I would have to patch that using TRS cables right? Normal cables won't cut it?
I realize I'm kind of answering myself, I've asked these type of questions in the past on here, but it's been so long since I've thought about this, I forget it sort of.
So my board has 16 XLR inputs with 8 Line in and "Pre outs" under 8 of the 16 XLR channels. So could I run 4 cables from the "Pre outs" from 4 channels into the 4 Line ins on the soundcard, and run 4 cables from the Line Outs on the soundcard into the Line Ins on the mixer, for later actual desk mixing?
This is kind of confusing I know, but any help is appreciate, and I'll clarify what I'm trying to say if anyone needs it. Thanks.
