What were you hooking the other cable to?Aww man, thanks a lot. Until now I have been using two separate cables. I still don't have the insert cable but I'm gonna buy it now. Thanks a lot again man. Hopefully my compressor responds after I do this.
Except that you would still hear the uncompressed signal coming through the channel.Aux send takes audio out of the mixer.
Returns bring audio back in.
So, another way you could do this is hook an auxiliary send to the compressor's input, then route the output to a return. This will allow you to use one signal processor for multiple channels.
That's one way. the more common way is to send a signal to two different busses and only compress one. It's easier to do with a hardware mixer.Is that a how people do Parallel Compression OTB?
