knightknife
So if i buy a mixer (Behringer EURORACK UB1202 Mixer) how would i hook it up to my computer to record?
just trying record....the mics require a pre amp and that mixer has pre amps built in so i thought it would be good idea.
You can buy interfaces that have mic pres built in, do all your mixing in the computer.
Check these out, scroll down to about the $80 range.
http://www.sweetwater.com/c695--USB_Audio_Interfaces/low2high
So why does just about every semi pro studio have a huge mixer board if you can just mix everything in the computer?
Alright, I am recording mainly acoustic tracks (ac guitar, vocals, cajon drum, maybe a bass guitar, and electric guitar). Will only need to use 2 - 3 mics at once.
The reason I was going to purchase the mixer was because I was going to not only use it in the studio, but for live performance. But if my recording would do better without the mixer and instead just use interfaces, than i guess i can just do that.
So I suggest you look at mixers with a USB output built into them. In these, the A/D is done for you so you get your mixer and your input for your computer in one box.
Thanks Guys! I will probably go with the usb interfaces for right now. Its cheaper and I can just mix the recordings on Logic express.
