My Name
I've worked out a way to set the bias traps.
the reason the multimeter shows no change when adjusting the traps is because the MM is not read small enough amouts of voltage. so if you rig up a the MM probes to the input of a level meter (on your pc or whatever) it will show a level that you can adjust.
does that make sense?
My comunications skills aren't great when it comes to writing so you'll have to bare with me
