C
Canobliss
Ive don a couple posts with similar questions already so i apologize for this one but I really need some specific help. Im trying to figure out how to treat my crappy room and have done a lot of research which has mostly confused me, do to the large number of options.
Below is a crappy diagram of my acoustically crappy room. Id prefer not to do any construction (might move in a couple of years) so am relying on acoustic products. the walls are dry-wall Note: the walls for the booth marked * are made from heavy packing blankets and are not soild walls.
I can get up to about $1500 to use if i sell off some equipment and currently have about 64 square feet of 2" foam and a pair of Mo-pads for my monitors.
Right now I am planning on doing something similar to the "acoustic 101 room" on Auralex's site here http://www.acoustics101.com/common/acoustics101room.pdf
Their room is similar in dimension but of course better designed and is only a control room. Going off of that I have 5 questions:
1) will this treatment plan work with my single room control/tracking setup?
2) I have seen many other places recommend absorption above the listening area where the "acoustic 101" room uses diffusers. Anybody have any preference towards either approach?
3) This room only has bass traps in the rear corners, are they not necessary in the corners behind the monitors?
4) How much coverage is necessary?
5) I know that thicker materials and space between the materials will absorb a more even frequency range. So im thinking that auralex foam isn't the best way to go. I could make my own panels, but im not the handiest person in the world so im thinking about buying panels instead if foam, any suggestions?
Thanks again everybody, your help is always greatly appreciated.
20'
| Tracking storage | 6'
| * Vox | 6'
| * Booth| ceiling 8.5'
| | 5'
| DAW/Monitors | 6'
15'
20'
| * Vox | 6'
| | 5'
| DAW/Monitors | 6'
15'
Other than that, you don't really need a dedicated diffuser for a room that small.
