Help
  • Thread starter Thread starter skattrbrain
skattrbrain
Hi im new to this. Im currently using an m-audio fast track pro through garage band. BUt i only seem to hear what im doing in one ear.
Is there anyway to correct this
Thanks
Pan Control
Make certain your pan control is not panned hard left or right. Panned up the middle should send signal to both sides.
If that doesn't fix the problem, check your output settings... Under the GarageBand menu, select Preferences, then Audio/Midi to check the output selection.
