G
gordone
But how does the sound get OUT of your PC and into the Mackie? I have the same setup and what I do is have my 2 sources (My Great River MP2) into the Delta's IN 1/2. This is what I select to record from in my software (N-Track). To monitor what I am recording, I use the Delta Control Panel to route IN 1/2 to OUT 1/2. OUT 1/2 goes into 2 line-level channels on my Mackie. Thus I can contol the level of each mic/keyboard/whatever as I'm tracking. I then instruct N-Track to output the master bus to the Delta's WAV OUT 1/2 and then direct this to HW OUT 1/2 from the Delta Control Panel. HW OUT 1/2 then goes into a stereo channel on the Mackie, so when I'm overdubbing, my Mackie goes something like -
Channel 1 - Channel 1 of my preamp (or keyboard)
Channel 2 - Channel 2 of my preamp (or keyboard)
Channel 5/6 - What has already been recorded on the PC, playing back as I overdub.
I have to remember to either turn my monitors off (which are plugged into the Master Out of the Mackie) or send Channel 1/2 and 5/6 to the Alt 3/4 bus, which I assign to the headphone output. This ensures that nothing comes out of the monitor speakers while I'm tracking.
Good luck! You have a nice setup there!
PS - I have the Delta 44, not the 66, but this should work with the 66.
MightyPOOsticK said:How do I listen to whats already been recorded?
I listen thru my computer thru cool edit pro.
The only reason I had headphones plugged into the mixer was because I wanted to hear what was being recorded.
