Walt-Dogg
If you combine two 8 ohm cabs you get 4 ohms, which will be just fine for the Peavey considering it can dish out a 2 ohm load with no problem.I just want some grit, which I think I said already. Even with the gain cranked all the way up I couldn't get any distortion, but maybe if I plugged it into the passive input? I dunno, that seems like it could be a bad idea with an active bass.
I was looking at the specs and the B200H says 200w @ 4 ohms, then it lists a couple Acoustic cabinets it could be matched with (B115 and B410), but both of those are 8 ohm cabinets. I thought the idea was to match impedance... am I missing something here?
I don't suggest the Peavey if you want a crispy distortion though as it has no master, just gain controls which only make it louder and boomier with a bit of fuzz not actual distortion. I'd suggest one of those small GK or Ampeg heads with masters and gains and giant EQs and running a pedal into it.
