Seafroggys
Okay so I showed a couple of people an early mix of a WIP on my album project. The first one said the bass guitar sounded like Midi, and the second said it sounded flat (not flat as in pitch, but in tone).
I went back to the mix and realized that long long ago, when I first recorded the bass part, I set the compressor to 16:1 (eck, that could kill everything). So I rolled it back to 9:1, raised the attack a little, took out some 400 and boosted a bit of 1k.
This is DI btw, hence the reason for the high compression ratio. So here's the updated mix, but I'd like to see if there's anything else I could do, aside from the obvious re-tracking. I also have a reamper available if you think amping it up may be a good idea, but my best amp at the moment is a 130 watt Peavey TNT combo unit.
http://soundclick.com/share?songid=7311751
