E
eirikur
Hi...
I wrote a post earlier about how my soundcard inputs are unbalanced, and my preamp only has balanced outs. Now, I solved this (I thought) by getting an external A/D box, which would accept the balanced output from the pre and turn it into SPDIF, since my soundcard also has an SPDIF input....
That SHOULD work fine, in theory... In order to get this to work properly, however, I would have to set my souncard as the slave and let the A/D box be master, to get correct clock signals.
And HERE's the problem... I can't get my soundcard to sync reliably to it.
The problem appears to lie with the soundcard (A creamware powersampler card), since I've tried to sync it with other SPDIF sources, as well as using a different cable.
Regardless of what sample rates I use, it is unable to sync properly.
Has sync, loses sync etc.. And when it is able to sync, it accepts fragments of sound that I send from the A/D converter... But I would like to record more than fragments...
Now.... anyone else had this problem with creamware boards, and figured out a way to solve this?
Alternatively, any good ideas for a "analogue" converter that would convert a balanced signal to an unbalanced signal, without affecting quality of sound?
The preamp, as mentioned, only has balanced outs, and I want to be able to "push" the pres output, otherwise I could just decrease the output volume from the pre with 14 dB, and everything would be fine...
Therefore: brilliant analog "box" that would do this "conversion" from balanced analog to unbalanced analog well?
Cheers!
Cheers!
One might discuss HOW much better balanced is etc, but the fact remains that it IS better.. that's why I want to use balanced, if I can.. and i should be able to..
