harddrive for 788
  • Thread starter Thread starter SMITHKI
SMITHKI
i was shopping over the weakend at the discount stores,all i could find is 40 and 80 gb.the has anyone heard of maxon hard drives.they told me that they are supposed to be low profile,but they ony carry 80 gb.can you put that large of a hard drive in the 788 or would you stick to the 60.could anyone give me the numbers for the right hitachi and the seagate that would work.i will probably have to buy on line somewhere.thanks for any info you can give me.
kirk
Here's what I'm using now. I tried (you won't believe it) about 12 different drives trying to improve performance, price, size, noise and temp.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=100658
If you want a 60GB, try:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=100639
If you use an 80GB, it will simply provide you with the 64GB max and a small amount will go unused, but it will still work.
I like 5400rpm drives (like the original.) They're quieter and cooler.
The links I gave you are a fine source. Cheap, fast and reliable.
Good luck.
