G
goldensolmusic
This forum has been an incredible value, any response or thoughts on this room would be appreciated more than you can imagine. I am trying to make the best out of a tough situation. I have included a diagram of the room bellow.
The Situation:
Due to partner disputes, had to leave the professional recording facility and now need to try and convert a back room in a downtown apt. to a small DAW/VO station to keep work flowing.
The problems:
Room is small, with an awkward shape, 1 large window and a neighbor that sleeps bellow the room.
The solution: (hopefully)
*Float a new floor on pucks with as 4-5 inches of high density 703 between the neighbor and I. To hopefully limit low end vibration and absorb most of mid/hi freq.
*Isolate smaller part of room with floor to ceiling panels to eliminate reflections in that zone.
*Position mix station so that part of the room somewhat behaves like rectangle.
*Use hardwood floors and rigid fiberglass btw ceiling beams (full coverage)
Questions:
**Is floating a floor (leaving a small gap around outside edges btw the wall and floor) a waste of time or will this significantly reduce noise to a lower neighbor and isolate low end vibration?
**Is this room just too small and awkward to use for projects when a good listening environment is required?
**Should the ceiling be lowered with panels to have a better ceiling/length ratio?
**Can anything be done about the window other than sealing it up?
If nothing else thank you all for a wealth of knowledge in the forum!
The Situation:
The problems:
Questions:
