BushmasterM4
I had some spare time today so I finished up a cover of ACDC's "Gone Shootin". Give a listen and let me know how the mix sounds. Musicianship wise I know its bad. But sound wise, let me have it. I did two mixes. One I got a little more agressive with a master bus compressor. The other I didnt use much at all. Im playing all instruments and singing as usual, thats why its sloppy
Anyway let me know if you like A or B better. Plus see if you can tell which has more compression (should be easy enough). Im on the fence about which sounds better.
A http://www.soundclick.com/util/getplayer.m3u?id=7249290&q=hi
B http://www.soundclick.com/util/getplayer.m3u?id=7249349&q=hi
Anyway let me know if you like A or B better. Plus see if you can tell which has more compression (should be easy enough). Im on the fence about which sounds better.A http://www.soundclick.com/util/getplayer.m3u?id=7249290&q=hi
