muttley600
Banned
I've pretty much said how it should be done.ok...I am with you. I don't think my guitars fall into the rare category of not being able to be made to play in tune. I guess its possible but for argument's sake and the sake of statistics lets say that my guitars are able to get in tune. Lets also assume that I want every note to fret in tune to a tuner, regardless of temperment problems and what 'sounds' right. my ears are accostomed to equal temperment anyway... if you have set up thousands of guitars, what steps would you take to tackle this issue?
Set the neck relief first, then check the nut slots to make sure the string hight is around the same as the first fret definitely not lower. Check for any high or low frets, Check neck angle, string up, reset the relief and adjust the saddle to play in tune. All this is done with good strings and the action set at the appropriate hight for that guitar and string gauge. Any intonation problems you have after doing this properly will be down to one of two things. First, the very nature of 12 ET and the physics of the vibrating string. These you can't change just work within. Or secound down to your own expectations and your ability to detect subtle tuning discrepancies. A third and less likely cause would be a fundemental problem with the guitar such as misplaced frets or bridge.
Sometimes I wish electronic tuners had never been invented because they lead to people identifying problems that are not there or have always been there. A good musician learns to tune his instrument so it is evenly OUT of tune throughout. This is best achieved after a good setup has put everything in place to achieve it. If you continue to try and get every note on your fretboard in tune with an electronic tuner you are wasting your time. What you need to do is even out the neck to play out of tune so that they are barely discernible if at all.
Last tip is to learn to rely on your ears and not an electronic tuner.
