FALKEN
yes, you can intonate so that the 12th fret is "in tune" with the open string. But what do you do when other frets are not in tune? what adjustments should be made?
When setting up a guitar I check intonation at 7th, 12th and 17th frets. If a guitar is right at these locations it will be as close to right all over as possible. Some guitars will not be dead on in every position so you just have to compromise and settle for getting as close as possible. I rarely find guitars which can be set up to be 100% in every fret position.
uhm, ok. I have been checking mine at the 3rd fret and the 15th fret...below the 12th fret tends to go sharp, and above tends to go flat. If you guys think this is a joke I feel bad for your audience.
In fact, most guys in guitar shops you pay to do you setups don't check it, either.
is that the one with the frets that angle? Never tried one...
Even in this thread some say it will never be perfect and others say it should be done as a matter of fact. I don't think temperment has anything to do with it. Each note on the fretboard should ring out "in tune" on an electronic tuner despite unequal temperment. I guess I can get it "as close as possible" but it drives me nuts.
You really have to read and understand more about temperament and 12 step Equal temperament in particular. The fact that you can get the notes to ring true on your tuner perfectly in tune for 12 note ET does not mean that you are in tune. Many, if not all of the intervals are a compromise. You will also struggle to get all the frets playing perfectly to your tuner and if you could when you give it to someone else to play it wouldn't be exactly the same simply because of his or her technique.I don't think temperament has anything to do with it. Each note on the fretboard should ring out "in tune" on an electronic tuner despite unequal temperament.
First part true, yes the higher the action the more tension you put on the string as you fret it so typically the note higher up the fretboard would play sharper. That doesn't lower the pitch of the frets below the 12 fret it, you are just not raising the pitch as much. You shouldn't need to raise your action to get it to play properly. If your frets are playing sharp below the 12th and flat above the 12th you have other setup issues. That is my point. It is a compromise at all places and everything you do has an influence. Its not just about action. It is a balancing act.It seems to me that a higher action would have more effect on pitch further up the neck, so raising the action would raise the fretted pitch more and more the further up you go, effectively *lowering* the fretted pitch on frets 2-10, if fret 12 is made to be even again. This is how I've handled it in the past but it sucks to raise your action just to get your notes to fret properly.
