Gefell UM92.1S Matched Set - Any Good on Drums
  • Thread starter Thread starter NL5
sdelsolray said:
I don't know. Alan Hyatt says his SP mics sound as good or better than expensive German mics.
.......I was just kidding.........
I have never heard a T3 actually. I had a U89, and compared it to my NTK and thought they were pretty close - The Neumann was definetley better though. However, that was through bad pre's and so-so converters. I expect I will hear quite an improvement this time around. :D
The cheaper grade mics are a lot closer to the high-end mics now - but just as good? I don't think so myself.
mikey@thecave said:
lets have a shootout-- :eek: a dual T#3 against Geffel :confused:
OK, send me your set of T3's and I'll record both at the same time, on the same drum set, in the same room, and we can compare. :D
Many decent inexpensive mics exist now, and they are indeed getting closer in quality to the high-end mics, at least in the LD area. The disparity that exists is less noticable through an inexpensive signal or monitoring chain, and generally more apparent with a quality signal and monitoring chain.
OK, send me your set of T3's and I'll record both at the same time, on the same drum set, in the same room, and we can compare. :p :p :p
Sorry no can do...She never leaves my side :oWhat ###Tube is in that mic 92
Well, that's gonna make the shoot-out pretty tough to do then.........
