Garage Door
  • Thread starter Thread starter boogieman481
This wont help you but if it is any consolation, I have the reverse problem. I have more trouble keeping noise out of my studio/practice room. I can't count the times when a lawnmower, barking dog, drive by stereo boomer, loud muffler or sirene has found it's way onto something I have been recording. We can practice in peace and quiet, but if someone presses the record button it seems like everyone in our neighborhood decides it's time to mow the grass.
ssscientist said:
How did you keep your hearing intact so that you can master as well as you do?
We wore earplugs. Aside from saving your ears, it also helps hear things clearer on stage.
bennychico11 said:
then apparently you've never been a classical musician or played in a jazz band because not all bands play in garages nor do all bands play the style of music you do.nor does everyone have a garage
You sure set ME straight.
Sure did.
Would putting some bass traps in front of the door help kill the bass sound leaving? or what about setting some up right in front of the kick drum?
No, and no. Would putting your hand 6" in front of your mouth make your voice seem quieter from ten fet away? Muffle the drums and turn down.
SPL meter comes in friday... as does some new insulation... we will see what happens
Keep in mind: the meter will be biased towards a given frequency, and will under-represent low freq. energy. However, if you measure the same way the law specifies, and you're under the limit, you have your defense all tied up You will need an unbiased witness when you test, and a responding officer will probably not be interested in the job...
I find hanging thick duvets, carpet and blankets etc. on walls with a 4 inch air gap gives a half decent reduction in volume.
I feel you pain though, we used to practise in my garage, its cold and damp and you can't play loud.
