FS: Focusrite Platinum Penta
  • Thread starter Thread starter mrbowes
mrbowes
mrbowes
Mint condition. Comes with power cord and will be well packed and shipped fast via USPS Priority.
Priced to sell at $250 shipped/insured
Product Description
Every dynamics processor you'll ever need, squeezed into one 2U rackmountable unit, the Penta will go down in your recording history as one of the best investments you ever made.
Designed principally as an affordable, high specification Stereo Analog Pre-set Compressor, the Platinum Penta provides a multiple of essential analog processing elements in a sturdy 2U 19 in. rackmount case. The unit features an entirely editable pre-set compressor offering a range of professionally compiled compression settings depending on the sound required or instrument involved. Its dynamic response can add a soft or hard knee shape to the compressor curve, and combined with TubeTran technology can emulate VCA, optical, and valve compressor sounds.
The unit also features the same discrete transistor mic-pre as the award winning VoiceMaster. Because the PENTA includes a single mic-pre, as well as full stereo circuitry, it's just as ideal for recording a mono signal as for compressing the final stereo mix. So the PENTA offers the project studio owner the opportunity to both track and mix-down adding the "Focusrite signature sound" to their future productions at an outrageously affordable price.
Features
Stereo signal path throughout
Focusrite Class A Platinum Mic-pre (with Phantom Power)
Direct inputs on the front fascia for instruments (e.g. guitar) and microphone (Both XLR and Jack)
Preset Compressor (16 pre-sets š all entirely editable)
Compressor features TubeTranÐTechnology (More warmth, less warmth, you choose)
Stereo Image Width Controller
A high level of metering to ensure optimum levels
Optional 24-bit/96kHz digital A/D output stage for state-of-the-art digital connectivity.
Technical Description
Specifications
Inputs and Outputs
All inputs and outputs are TRS Jacks and accept unbalanced (-10dBu) and balanced (+4dBv) signals Mic Gain: 0dB to 60dB
Line Gain: -10dB to +10dB
Instrument Gain:
- 0dB to +20dB
- Impedance: >10kOhms
Compressor
Each individual preset is entirely editable. Compression Gain: -10dB to+10dB
Make up Gain: -10 to +10dB
Overload
+20dB
Performance Specifications
Frequency Response Bypass In: -1dB down at 20Hz and 200kHz
Compressor In: -2dB down at 20Hz and 200kHz
THD
Measured with input signal frequency of 1kHz at 20dBu level and 20Hz /22kHz bandpass filter. Bypass In: 0.0008%
With compressor in, 6db of compression and 6dB of makeup gain: 0.001%
Noise
Measured with 20Hz/22kHz bandpass filter. Bypass In: -92dBu
Compressor In
